Re: 1944 Farmall H, tell me if these options are o
Posted by Paul in Mich on July 12, 2005 at 10:15:38 from (205.188.117.73):
In Reply to: 1944 Farmall H, tell me if these options are origi posted by FmrBoy on July 12, 2005 at 07:06:11:
Fmrboy, The earlier models did have the pulley engage lever on the clutch side and did not extend through the steering post. i"m not sure what year that changed, but i"m thinking on the post war models and about the same time that the starter switch was relocated from the fuel tank pedistal to a bracket just below the light bar on the left side of the steering post. The early H did not have the same foot lever to engage the starter as did the later M, but did as you say have a pin which went through the steering post and rest against the starter switch. It took a twist of the foot to engage the starter switch. The curl you speak of is the bracket which holds the hydraulic control lever. If you dont have the belly pump hydraulic system, then you wouldnt have the lever.
Post a Followup
