Re: F12/F14 Timing/fail to start
Posted by KevinH on July 12, 2005 at 19:02:25 from (64.139.245.186):
In Reply to: F12/F14 Timing/fail to start posted by DA@STL on July 12, 2005 at 18:47:36:
Been there with a '35 F12 and I feel your pain. It took me 3 years to finally get mine right. The culprit? Gap. Plug and magneto...mine would fire beautifully out of the cylinder, but wouldn't crank with the plugs in for anything. Mag points on an F4 should be .013 and the plugs I think are .020-.025. The plug gap was my biggest problem. Also, open the drain on your carb and see if you have fuel. If you do, most likely your pump is not the problem. Good luck, Kevin
Post a Followup
