Re: Farmall BN engine surge
Posted by Roger WI on July 12, 2005 at 19:08:00 from (69.58.151.92):
In Reply to: Farmall BN engine surge posted by RobPA on July 12, 2005 at 18:43:02:
Rob, The torch may light because the manifold is hot enough to light the propane (I can't remember the auto-ignition temperature of propane). Also could be a hole in the exhaust manifold or gasket. As to the surging, you may need to adjust the anti-surging adjustment on the governor. That is the screw with the half nut over it. Adjust it in or out to see if that helps. Roger
Post a Followup
