Re: Which Tractor Would You Recommend
Posted by Dr.EVIL on July 13, 2005 at 06:49:11 from (216.136.115.250):
In Reply to: Which Tractor Would You Recommend posted by Farmall Frank on July 13, 2005 at 06:32:55:
I'd definitely use something newer, 706/806, 756/856/826. Even a 656/666/686 would pull anything better than Your 400D would. I'd try to stay with a diesel tractor, even with the prediction of VERY expensive fuel this fall, with a gas tractor You'll burn WAY more fuel to do the same work, and You'll burn a LOT of fuel/gas discing 160 acres.
You didn't mention what crop is on the ground now but wheat doesn't need much soil preparation to grow. A good discing, and either drill the seed in or even use a broadcast seeder and just lightly re-disc. I suspect Your Dad wants the wheat as a cover crop for some type of hay.
Post a Followup
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
