Re: Help ID 706 hitch
Posted by caseyc on July 13, 2005 at 14:45:26 from (66.17.100.10):
In Reply to: Re: Help ID 706 hitch posted by Uncle Willy on July 13, 2005 at 14:21:09:
if you really want to use the top link then you need to cut the top part of that hitch off, just leave the the two inserts on the bottom. there is a plate that will bolt to the diffy that will have the holes to attach the top link then. that plate can be found in junk yards.
casey
Post a Followup
