Re: Help ID 706 hitch
Posted by Ksfarmmer on July 13, 2005 at 21:00:07 from (24.255.226.14):
In Reply to: Re: Help ID 706 hitch posted by Uncle Willy on July 13, 2005 at 17:59:26:
The more I remember about the one we had, the top link was adjustable. You should be able to fabricate something. It was like a piece of all-thread with a U-shaped bracket on each end. The "U" brackets each had a pin inserted, one for the implement (the normal top hitch) and the other into the top of the hitch conversion. The all-thread provided some adjustment for connecting the equipment and/or to adjust the equipment height somewhat the same as the normal link. You have already figured out you will not have the same amount of adjustments. So goes trying to convert 2 pt to 3 pt.
Post a Followup
