Re: Cub Quit
Posted by El Toro on July 14, 2005 at 12:32:10 from (205.188.117.73):
In Reply to: Cub Quit posted by Farmall Ed on July 14, 2005 at 11:24:51:
Hi Ed, If you have voltage at thr coil, Use a lite or volt meter to check for voltage at the points. Remove distr. cap, rotor and remove coil wire from the cap and hold within 1/4" of ground.
With points closed & ignition switch on, snap the
points open a few times and watch for a good spark
at the end of the coil wire. Don't get bitten!
If you have no spark your points may need you to pass a point file through those new points. Check that gap too. Still no spark could have bad condenser or coil. Hal
Post a Followup
