Re: Super m disk brakes?
Posted by DWV on July 14, 2005 at 13:23:35 from (205.188.117.73):
In Reply to: Re: Super m disk brakes? posted by John M on July 13, 2005 at 17:42:05:
Its a lot of work,the bull pinion shaft bearing cages from SM through 450 need to be used in sides of M housing.(the disc brake housings bolt to these)The side housings use a bigger hole for the differential carrier bearings which means the
SM diff carrier needs used to match bearings.SM
and M use same ring gear so M will bolt to SM
carrier.Use of SM brake linkage and parts required
to complete.
Post a Followup
