Re: leaking gas tank on 350
Posted by Farmer Bob on July 14, 2005 at 21:35:19 from (71.2.218.44):
In Reply to: leaking gas tank on 350 posted by Jim in Alaska on July 14, 2005 at 19:03:21:
The remedy for that leak that I prefer is to drain the tank, disconnect the fuel line at the sediment bowl, unscrew the top housing of the sediment bowl from the bottom of the tank. Clean up the threads on the sediment bowl and apply a coating of aviation type permatex sealer. Let set up for a couple minutes and then screw it into the bottom of the tank. Make sure you don't cross thread it as it is a very soft pot metal with 3/8ths pipe thread. Other may have different favorite fixes. Your mileage may vary.
Post a Followup
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
