Re: W-4 rear axle seal
Posted by John M on July 17, 2005 at 08:59:45 from (64.53.75.223):
In Reply to: W-4 rear axle seal posted by Redline on July 17, 2005 at 06:12:58:
Hydraulic puller!With the jack,your only pushing in one spot,take out the jack,rotate the hub and put your jack back in,keep doing that and your PB,and she will eventually come off.You could also take off the big bolt and drive it in circles,turning the in the diurection of the tire you need to get off and it will start to slide,but be careful,it can and will come off.(Dont ask me how I know).When I did the other side, I rented a hydraulic puller!
Post a Followup
