Re: Converted Fuel H
Posted by Loyd in Texas on July 17, 2005 at 11:35:34 from (65.40.209.150):
In Reply to: Converted Fuel H posted by Kyle Wehmeyer on July 17, 2005 at 09:51:05:
The compression ratio is different for the kerosene engines. They have different heads and valve assemblies.
the gas version had the cold manifold. Your manifold should have an adjustment or heat control valve.
The simple answer to your question is yes. The manifold is heating the gas too much causing a loss of power.
Too run on gas today I would change the manifold and carburetor. Just my two cents worth.
Good luck
Post a Followup
