Farmall Tractors Discussion Board
Lamps
Posted by T'other Fred on December 17, 1999 at 20:09:52 from (206.72.4.15):
Greeting;
Is there a bulb which will work in the Farmall single terminal style housings of 50 years ago?
A couple of weeks or so ago someone posted a part number (358893R92) for 12 volt single terminal flood lamps for the Farmall lamp housings. I have been carrying that number around ever since, and finally got into the dealer (Case IH) today to learn the number is not in their computer. The counterman looked in a parts book and found it was a good number, once. His solution is new lamps and housings at $43. each. My present un- solution is halogen fog lamps. Although they put out a tremendous amount of light it is focused in such a thin band to light the road ahead that it is not worth much lighting the ground around the tractor at three MPH.
Fred
Post A Followup
: Re: Lamps
