Re: F20 cracked water jacket
Posted by F-Dean on July 18, 2005 at 14:51:03 from (12.74.46.137):
In Reply to: F20 cracked water jacket posted by Bob Spooner on July 18, 2005 at 12:00:06:
Here is what I did and it worked:
(1) Have a local blacksmith or a good welder weld the crack. (2) Cover the exterior with epoxy to smooth the surface and prevent rusting. (3) Paint the epoxy. (4) Seal the lower pipe to the block - a piece of an old tube makes an excellent seal. (5) Pour radiator sealant into the block to a level above the crack. (6) Let stand for several days while you work on other parts.
Post a Followup
