Re: H flooding/hunting
Posted by Roger WI on July 18, 2005 at 18:50:06 from (69.58.151.152):
In Reply to: H flooding/hunting posted by greg wilson on July 18, 2005 at 18:23:01:
Greg, Sounds like the needle valve is sticking open probably with some piece of debris under it. Might try just tapping lightly on the carb with the gas on to see if it stops. Also try draining the carb and then turn on the gas as that might clean out the needle valve, otherwise you will probably have to take the carb apart again. Others might have some other suggestions. Roger
Post a Followup
