Re: What engine might I use??
Posted by El Toro on July 19, 2005 at 04:00:05 from (205.188.117.73):
In Reply to: Re: What engine might I use?? posted by farmalltom on July 18, 2005 at 19:34:45:
There's a lot of things to consider when replacing
an engine. These are just a few: motor mounts,
flywheel accepting pressure plate, pilot bearing
for transmission shaft, bell housing and I'm sure there's many more that I haven't listed. A bigger
engine will create more heat and then the radiator may not be large enough.
It may be better to put in an oversize sleeve kit and pistons, if it has sleeves. It's going to be a hassle if you swap engines. I put a V8 283
Chevy engine in a truck that came with a 6 cylinder. That was a hassle too, different motor mounts and drive shaft too short just to name few.
Hal
Post a Followup
