Re: Cub mower deck mounted - need belt help
Posted by El Toro on July 19, 2005 at 05:20:19 from (152.163.101.13):
In Reply to: Cub mower deck mounted - need belt help posted by Brent in IA on July 18, 2005 at 13:52:44:
Hi Brent, I called Hoober in Delaware and they have belts (3) for the C3 mower with the fasthitch. You need to tell them which hitch you have. The cost was $56.00 for the 3 belts. The matched set of 2 that are driven by the center pulley has the P/N 478263R1. I think these 2 would be the same with either hitch. Hal
Post a Followup
