Re: How much movement is ok on F-20 Rear bearing
Posted by El Toro on July 19, 2005 at 06:37:27 from (205.188.117.73):
In Reply to: How much movement is ok on F-20 Rear bearing posted by Paul G. in Mn on July 18, 2005 at 13:30:27:
If you're referring to the rear main it should only have from .002"-.003" clearance. If it is you drop the oil pan and check the clearance with
plasti-gage. Inspect the crankshaft too> Hal
Post a Followup
