Re: 560 D fast hitch
Posted by Hugh MacKay on July 19, 2005 at 09:48:27 from (209.226.247.81):
In Reply to: 560 D fast hitch posted by Ronald on July 19, 2005 at 08:20:58:
Ronald: If the hitch gradually goes down then at some point hydraulics bring it up to the pre set position the the leak could be the only problem.
If however the hitch is always hunting, I would be inclined to believe problem is in the tele-depth control. The valve itself has a small set of spider gears that do wear out. When this happens, usually the hitch will never stay in one position, just continuous raising and lowering.
Let us know which you believe it to be doing and someone will advise your best repair approach.
Post a Followup
