Re: Oil Pump
Posted by captaink on July 19, 2005 at 13:06:41 from (66.115.214.56):
In Reply to: Oil Pump posted by Plains Hunter on July 19, 2005 at 12:08:48:
First, I would inspect the gasket in the pump where the plate bolts on for gaps or missing pieces of gasket. These plates will sometimes warp causing gaskets to blow out.
If you don’t find anything there, then it is possible that the cam bearings are worn and you are loosing oil pressure there.
Good Luck!
Post a Followup
