Re: Gas in oil
Posted by old on July 19, 2005 at 21:01:20 from (207.69.137.135):
In Reply to: Gas in oil posted by Mike3501 on July 19, 2005 at 20:38:25:
I'd start at the carb. Do you shut the gas off when you park it? If you don't the float needle maybe leaking a little and that will get gas in the oil.
Post a Followup
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
