60 C-3 mower on Cub --- too big?
Posted by Brent in IA on July 20, 2005 at 19:03:20 from (199.120.87.137):
First off, thanks to everyone who has helped over the past days identifying my mower deck, helping get it mounted, and helping out with belts. So far I have gotten it mounted, figured out the wrong belt (1 long one instead of 3 separate ones) came with it and I replaced them with correct ones, and have got it running without belts popping off. My issue now is, when I engage the PTO it really lugs the engine down and I can barely go in 1st gear without killing the engine, even with the deck up in the air and not cutting grass at all. I loosened all the belts past where I thought they should be and that helped some but it still wouldn't cut grass. So...I removed one of the end belts so only 2 blades were spinning and again that helped a little, but not enough to mow. If I disengage the PTO the engine roars back up to normal speed like nothing. I chekced and rechecked belt tension, I can spin all the spindles by hand easily (even with belts on), and the idler pulleys spin fine also. Am I asking too much of the Cub to run this mower? I thought trying with 2 blades (~40 inches cutting) would give me an idea if I could handle a C-2 mower or a 42 inch Woods but I don't think it could even do that. Sorry about long post but I need to get this mower working in the next few weeks as my brother is coming 1200 miles to pick it up. Thanks in advance!
Home
| Forums
Today's Featured Article -
Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
