Re: Oil Pump
Posted by Easy on July 21, 2005 at 00:34:26 from (198.208.159.14):
In Reply to: Re: Oil Pump posted by Michigan Dave on July 19, 2005 at 20:23:28:
When I rebuilt my H a few years ago, I found that the gears had worn a path in the cover. I took the cover off and surface ground it to flat. I took the gasket out entirely. I would also check the pressure relief valve, the spring might be gone. My oil pressure is excellent. I tried for .001 head spacing. Easy.
Post a Followup
