Re: Fast Hitch Prongs Dimensions
Posted by Hugh MacKay on July 22, 2005 at 16:28:07 from (216.208.58.168):
In Reply to: Fast Hitch Prongs Dimensions posted by Joe Kimbriel on July 22, 2005 at 12:24:37:
Joe: your 300 will use the large fork. To use a small fork on your tractor hitch one must use a 1/2" filler plate under the fork on each side. That is the 1/2" gab is speaking of.
I made some of these large forks and used 1-1/8" x 3" steel. Worked well, but was hard obtaining the taper on the sides. If I were doing it again I would use 1" thick material and weld on a wear plate at large end.
Post a Followup
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
