Re: SMTA Mystery Bearing
Posted by lee on July 24, 2005 at 17:45:35 from (68.225.113.254):
In Reply to: SMTA Mystery Bearing posted by GordoSD on July 24, 2005 at 06:24:26:
I would put the pinion and bevel gears right back where they were as regards the shims and backlash. Don't try to correct the backlash back too specs. You'll put the gears out of the wear pattern and likely doom the gears to howling or worse to failure. If the gears are excessive worn they need replaced.
Post a Followup
