Re: Need Help on 3pt hitch
Posted by Dave in CT on July 25, 2005 at 04:31:03 from (4.245.218.85):
In Reply to: Re: Need Help on 3pt hitch posted by Triker on July 25, 2005 at 04:03:21:
Yeah, I'm in the same boat. The most common setups just put a breather on the second port of each cylinder and let the weight of the implement bring the hitch down. I've read accounts where folks eventually want the down pressure so I'm looking for a way to get it plumbed that way from the start. I'll post my solution here. As to which port, you can use either front port, or both, for lifting the hitch. The third, rear port on the clutch-pedal side is for a delayed lift of the rear of the implement. It kicks in after the forward ports have reached top pressure. Unless you are using an implement that would require the back end to be lifted after the front, you can just leave that rear port capped. I think the most common way folks plumb their hitches is to run one line from either forward port back to a T located near the back end of the trans cover plate. From that T, two hoses go to your two cylinders. They do it this way to leave the other port available for other hydraulic applications, such as a front loader or, in my case, a front snow plow blade. I've also heard of setups that just run a hose from each of the two forward ports to each of the hitch cylinders. Whatever you do, I'd recommend getting those hoses well mounted with a good abrasion-resistant bracket and cover the area that runs by your feet with some sort of metal shield. You don't want to wind up with an amputated foot or foreleg because of a pinhole leak that develops years down the road. There's a hose shield pictured this way in the H Operator's manual so they probably can be gotten from the boneyards.
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
