Re: Diesel engine question
Posted by Janicholson on July 25, 2005 at 09:28:12 from (199.17.6.70):
In Reply to: Diesel engine question posted by Tom in Mo. on July 25, 2005 at 05:20:13:
A diesel being run down a hill (within normal RPM range) is pumping a bunch of air through the cylinders. When it has been worked hard, it is as hot as it can ever get, and the carbon in the ports and chambers and exhaust manafold will be near incandescent. As the fresh air hits these deposits, they ignite and burn out (it is kinda like a chimney fire in house, but not nearly as serious). I believe it'll be fine. This is especially common when the engine has been used lightly for a spell, or has not gotten up to full run temps and stayed there for an hour or two. It should mellow out after a few hard hours of work.
My two cents, Jim Nicholson
Post a Followup
