Re: timiing
Posted by El Toro on July 25, 2005 at 17:45:33 from (64.12.117.13):
In Reply to: timiing posted by lasher on July 25, 2005 at 16:26:36:
If the engine is running you can check the timing
with a timing lite. Put a chalk mark on the notch
of the damper pulley so it can be easily seen.
Hook timing clip to No1 plug and power leads to battery and let the engine idle.
When you squeeze the trigger on the lite it will blink every time No1 plug fires. Hold the lite
near the timing pointer on the left side of the engine and squeeze the trigger. The chalked notch should be aligned with the pointer, if it isn't
have someone to move the distributor very easy until marks are aligned. You may need to loosen the distr. holddown bolt. Hal
Post a Followup
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
