Re: help with 504 oil pan bolts
Posted by CNKS on July 25, 2005 at 19:42:28 from (204.249.178.138):
In Reply to: help with 504 oil pan bolts posted by cjm in wi on July 25, 2005 at 19:32:22:
I don't have a 504, but all the pans I have seen have the same diameter bolts. First thing to try is to get the correct size tap, and try to rethread, or at least "repair" the threads. 2nd choice is to use a heli-coil, which I believe requires enlarging the hole. If you use a Permatex type gasket making product, you may be able to get by without those bolts, but I have trouble stopping leaks with all bolts in place.
Post a Followup
