Re: 1086 transmission woes
Posted by the tractor vet on July 26, 2005 at 16:30:12 from (4.124.69.63):
In Reply to: Re: 1086 transmission woes posted by Bentwrench on July 26, 2005 at 06:33:06:
Well then that is the speed trans and it is not that bad of a job but ya still have to support the ft. of the cab and do a double split ya don't have to remove the T/A but don't screw up on the spacers or just how the gears go in and if ya get used gears make sure that the # match . When installing the lower counter shaft tighten up the nut tight then back off and then snug up and drill and pin the nut to the shaft with a 1/8th x1/2 roll pin.
Post a Followup
