Re: What is the problem?
Posted by El Toro on July 29, 2005 at 08:55:35 from (152.163.101.13):
In Reply to: Re: What is the problem? posted by Allan in NE on July 29, 2005 at 07:33:00:
Allan, That wouldn't surprise me on a valve job. Glad you sent some of that cool weather east. The corn and soybean crop looks to be very good here in MD.
Once you lose that rust inhibitor in your cooling system it will work on freeze plugs
and probably on sleeves too. Permanent doesn't mean forever. Drain and flush the cooling ststem
and install new antifreeze every other year. Hal
Post a Followup
