Re: 560 PTO trouble/Value of 400 PTO unit
Posted by the tractor vet on July 29, 2005 at 20:40:05 from (4.124.91.7):
In Reply to: 560 PTO trouble/Value of 400 PTO unit posted by K.B.-826 on July 29, 2005 at 20:05:08:
No , as the shaft speed are differant due to the differant gearing down off the pressure plate to the thru shaft.
Post a Followup
