Re: oil on the outside of spark plug
Posted by Janicholson on July 30, 2005 at 15:15:53 from (66.173.50.111):
In Reply to: Re: oil on the outside of spark plug posted by Digger on July 30, 2005 at 11:04:44:
Idea the sparkplug is cold (compared to the combustion chamber) as a result the gasses leaking out condense on the plug, forming the deposit. Two possible answers.
#1 The threads leak (as mentioned)
#2 The shell of the plug leaks
I have seen both!! the sparkplugs (I hope non-Champion) need to be torqued into the "Cleaned" holes (a round wire brush used to clean tail light sockets work well professionals do it) and they need to be installed with Permatex corp Molybdnum disulfide anti-sieze compound (silver gloppy stuff). Coat the threads of the plug with at least a farmer match head size dollop. Then tighten them in.
If the metal part of the plug looks fairly clean, but the insulator (white part) is oily, the plug is leaking and needs to be replaced. I've seen tractors (and cars/trucks) that do not burn oil mess up a bad set of plugs, or plugs not lubed or torqued correctly.
Good luck, and let us know of your results.
Jim Nicholson
Post a Followup
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
