Re: Super A Firing on 3 Cylinders
Posted by CNKS on July 30, 2005 at 19:40:34 from (204.249.178.138):
In Reply to: Super A Firing on 3 Cylinders posted by stan2270 on July 30, 2005 at 19:34:20:
You didn't mention the cap or the rotor. Also, your distributer shaft could be worn, so that the rotor and the #4 terminal don't have the proper clearance. Yes a bad valve or improper clearence can cause the same symptoms. In that case, though, the #4 plug should still be firing. You can take it out, ground it and check.
Post a Followup
