Re: Farmall Id
Posted by Jim Broughton on July 31, 2005 at 21:55:08 from (4.255.70.243):
In Reply to: Re: Farmall Id posted by CNKS on July 31, 2005 at 19:49:59:
The battery set up on that should be positive ground, and if battery is good, check out the starter solenoid on top of the starter. If either the solenoid or the starter are bad, repairing either is not too expensive. P.S. Check out the starter using jumper cables or long battery cables see if it turns over ! Really it's an easy fix, so enjoy!
Jim
Post a Followup
