Re: Battery Drain
Posted by da-bees on April 06, 2009 at 20:59:45 from (76.187.56.150):
In Reply to: Battery Drain posted by Tom in Iowa City on April 06, 2009 at 20:24:11:
I don,t think you lost ground.It would appear you may have created a short circuit.Disconnect- cable and RECHARGE BATTERY.using a two wire buzzer or bell same voltage as battery,connect one wire to vacant bat.post & 2nd wire to loose cable.If there is a short,buzzer will sound.Duplicate knob position that caused problem,buzzer should sound.While buzzer sounds,move,wiggle, disconnect until buzzer stops.THERE IS THE PROBLEM.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
