Lost power on Cub after 30 minutes
Posted by Walton on August 01, 2005 at 06:40:35 from (209.205.136.155):
I"m losing power on my IH Cub After approx 30 minutes of mowing, It just chokes down and barely runs. Runs well when mower not engaged. If I wait till the next day, it runs fine for a short time again. I"ve changed the coil, Plugs, condenser, points, set the timing. The screen in the Carb. is clean. Any suggestions? Could there be trash in the carb?(But why does it run fine in all gears except when mower engaged?) I changed coil twice (just to see) it gets pretty warm to touch, is this normal?
Post a Followup
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
