Re: Farmall 350 Hydraulics
Posted by Janicholson on August 01, 2005 at 14:11:23 from (66.173.50.20):
In Reply to: Re: Farmall 350 Hydraulics posted by Ken(IL) on August 01, 2005 at 11:34:41:
If one of the spool (control)valves has its switch out of place the system can lock up as described. the switches are on the spool end of the valves and are roll pins under a sheet metal detent strip. I think they should be counter clockwise for normal two way use. If other than this it could be a stuck open pressure regulator spool. A manual is needed to proceed to these steps.
l o luck
Jim Nicholson
Post a Followup
