Re: Bobcat value/auction?
Posted by hbarnhardt on August 02, 2005 at 06:16:43 from (208.5.222.89):
In Reply to: Re: Bobcat value/auction? posted by old on July 29, 2005 at 08:17:43:
Better check age????? Tires???? And then run at work until the mchine reaches operating temp. We have several Bobcats, all fine machines, but we have also bought bobcats that were total duds.
If it has the hours you suggested, the tires should be almost worn out. If (and there are a lot of ifs) its in good shape, then the price should be around 7K - 8K. No more.
Post a Followup
