Farmall B's
Posted by SeeingRed@PA on August 02, 2005 at 22:12:11 from (159.214.124.1):
I just purchased a Farmall B. I suspect it is a BN because the rear isn"t the typical offset wide look, I am just not sure because I am unable to find a serial plate on the tractor anywhere. Is there another way to be sure other than to measure the rear axle? If not then where should I take my measurements, inside the tires or outside the tires? Thanks for the help.
Post a Followup
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
