Re: Thorns+Front Tires=:(
Posted by RustyFarmall on August 03, 2005 at 05:52:13 from (199.120.81.246):
In Reply to: Thorns+Front Tires=:( posted by SGT K on August 03, 2005 at 05:29:32:
Any tire shop that handles ag tires will have the 3 rib in the size you need, either 4 ply or 6 ply. I can also tell you that a locust thorn will go right into a 6 ply tire just as easily as a 4 ply. Hedge thorns take a little longer, but will eventually work their way in also.
Post a Followup
