Re: Govenor problem fixed
Posted by Janicholson on August 03, 2005 at 15:01:07 from (66.173.50.33):
In Reply to: Govenor problem fixed posted by Mels on August 03, 2005 at 13:52:49:
The choke rod (shaft should never see gasoline. If it does it is flooding from the carb float/needle valve. always shut off the fuel at the tank when not in use. fix the flooding before you runn it much at all. See carb flooding in archives.
good luck Jim Nicholson
Post a Followup
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
