Re: 300 utility wont go into 5th gear
Posted by Bob M on August 04, 2005 at 06:40:38 from (151.190.254.107):
In Reply to: 300 utility wont go into 5th gear posted by Brian in Wisconsin on August 03, 2005 at 20:18:54:
Could be be a combination of a worn shift lever tip and shift lever pivot, aggravated by partially worn 5th speed clutches.
Try removing the shift lever (drive the cross pin out of the pivot), then use a prybar or a big honkin' screwdriver to slide the LEFT side shift rail inside the tranny as far forward as it will go. If road gear is now engaged it says the direct (5th gear) clutches are not yet completely trashed - the problem rather is a worn shift lever.
Post a Followup
