Re: 300 utility wont go into 5th gear
Posted by Brian in Wisconsin on August 04, 2005 at 13:01:05 from (208.134.202.37):
In Reply to: 300 utility wont go into 5th gear posted by Brian in Wisconsin on August 03, 2005 at 20:18:54:
To answer the question by Nat it wont go into 5th gear, does not grind. I thought it might be the fork also but dont want to buy it unless I know for sure. Brian
Post a Followup
