cylinder heads for Farmall H
Posted by David Bounds on August 04, 2005 at 18:59:39 from (205.188.117.73):
I am restoring a '41 Farmall H. I put a new sleeve and piston kit in the block. The kit was an overbore with domed pistons for a high compression gasoline engine. I have two tractors so I may choose the best parts from both to make one good tractor. My first head was cracked and frustratingly thrown away by the machine shop. My second head was good and I had it redone at a different machine shop. I believe the head I have was made for burning kerosene. The casting number I believe is 8776D. My question is what difference will I have with using this head as opposed to a high compression gasoline if any? What should I expect?
Post a Followup
