Re: F20 Connecting Rod Inserts
Posted by James Herrman on August 04, 2005 at 22:11:24 from (209.102.161.129):
In Reply to: F20 Connecting Rod Inserts posted by Dan Oehmke on August 04, 2005 at 20:15:40:
Not sure if inserts are available. Believe that .005 is the correct clearance for the rods and yes, shims are used to adjust the clearance. You can take a piece of shafting and turn it to the 2.23 dia and scrape the rods and caps round in order to fit. Use some prussian blue and mix it with vaseline and keep fitting the shaft to the rods and caps. You will be able to see the high spots and keep scraping the high spots down until you get most of a full bearing area where the areas are all blue. Had a similiar problem with my 29 regular and did the same. By "spotting" with the blueing compound, you will be able to make the rods fit the crank. Be careful and take your time and do not take a lot of the babbitt off the ends of the rod or cap. Good luck and hope this helps you and does not confuse you even more. If you find a place for inserts, please post it. Thanks for listening and others may have other ideas, but this worked for me. I took this route because of low RPM and also limited use. At least my rods are round and you should be able to do the same. JIM in ILL.
Home
| Forums
Today's Featured Article -
Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
