Re: Farmall Cub Mounted Equipment on a Lowboy?
Posted by Rudi on August 05, 2005 at 05:11:44 from (69.195.156.80):
In Reply to: Farmall Cub Mounted Equipment on a Lowboy? posted by IdaRed on August 04, 2005 at 17:30:18:
Red:
As Bd mentioned, ALL THE MOUNTING BRACKETS are different, mostly because of two things :
1. The Lo-Boy is 8 "'s shorter than a Cub
2. The finals are rotated 90 degrees, so the brackets from a Lo-boy will never work on a Farmall and the brackets on a Farmall will never work on a Lo-boy.
If the piece of equipment you are trying to mount is scarce, then you might want to consider the expense of having mounting hardware fabricated.
I think the only equipment that would even be interchangeable would be the Fast Hitch Implements, but I have not seen many, so I am not sure.
I can saw with a little experience that the mounting brackets for a mower are definitely different between the Lo-Boy and the Cub.
Post a Followup
