Re: 2 questions for a Farmall A
Posted by Some more info, thanks gu on August 06, 2005 at 06:08:37 from (216.187.161.102):
In Reply to: 2 questions for a Farmall A posted by Steve in MT on August 04, 2005 at 20:36:20:
Some more info on what I did. The original front axle assembly as badly broken and welded. It looked as tho someone hit something with the right front wheel and I mean HARD. The center tube was split from the slit all the way to the pivot pin and down to the bottom of the tube. The center tube and axle knee was welded back together. I couldnt find a good center tube anywhere around this area (Billings) and had to buy one off of ebay. The replacement center tube looks to be from a lot newer tractor as it has a factory reinforcement "Cone" welded to the pivot axle shaft housing on the back side. I was able to tell which side was which as the center tube had some wear marks from the U bolt. If the center tube is mounted in a vice with the pivot shaft level, then the knee is angled either forward, or rearward, depending which side is up on the center tube. Even putting a long bolt in the end of tube shows that there is some caster in it. Checking the good side of the old center tube shows that the knees were straight up. Im guessing that some where along the IH line, a decition must have been made to give it some positive caster???. It does have a bit of positive camber as per advice left for my question. I guess Im going to go ahead and leave the positive caster angle alone and try it. I can always weld the holes shut and redrill at a later date if need be. The Threshing bee is in 2 weeks and I need to have it ready for the show. FUEL LINE, Im going to use the steel with the compression fittings. I was afraid that the copper would be too soft and break. Thank you all for taking the time to answer . Steve
Home
| Forums
Today's Featured Article -
Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
