Re: Maytag, O/T but please help!
Posted by KevinH on August 07, 2005 at 08:41:18 from (64.139.245.186):
In Reply to: Re: Maytag, O/T but please help! posted by Allan in NE on August 07, 2005 at 08:30:11:
Thanks, I can't seem to figure how to bolt up the engine to the washer. The washer is a 1937, the engine is a model 72 so it should bolt up according to the limited info I found. But the bolt holes just won't line up. BTW, those spinners sure look good after the little workout you gave them!!
Post a Followup
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
