Re: H Starting Problem
Posted by El Toro on August 07, 2005 at 10:44:39 from (205.188.117.73):
In Reply to: H Starting Problem posted by RandyMcc on August 07, 2005 at 10:15:27:
You could run a compression check on the cylinders
to see what your readings are. Low compression
is good indication of worn cylinders, rings and valves not seating. What shape is the battery,
battery cables and ignition? Pull out the coil
wire from the cap and have someone attempt a start using the starter with the ignition on
while you hold the coil wire within a 1/4" of a good ground. Should be a good hot spark, if good check at the sparkplugs too. Hal
When we had an H we didn't give it much choke when starting.
Post a Followup
