Re: 44 Farmall H engine questions
Posted by Janicholson on August 08, 2005 at 05:45:17 from (199.17.6.77):
In Reply to: 44 Farmall H engine questions posted by Chad from Michigan on August 08, 2005 at 04:16:17:
With what's been said, I'd do the following:
1) Using insulated spark plug wire pliers, pull plug wires off and put them back on one at a time till you determine which cylinder it is.
2) Listen with a piece of small diameter rubber hose (1/4"I.D.) around the intake area/manafold to hear the hiss of a vacuum leak.
3) Check the distributor bushings. If the rotor shaft can be wiggled in any direction more than .003" the bushings need to be replaced.
4) Do a cylinder leakdown test on the suspected cylinder (described in archives)
Good luck, it should be identifiable.
Jim Nicholson
Post a Followup
